Wanna buy » handlebars
gorman
I have the exact same setup on my bike (Rox risers and a Renthal CR fatbar). Cables and brake lines are fine - the brake lines are close to the limit but not tight, even with the forks extended to their max (like when you wheelie :-))
2004 Multistrada 1000DS
1997 900SS
1982 900SS
wangiles
Hi! I know this is a bit too late to ask but will the rox bar risers affect the DP steering damper? Is a fat bar better than normal bar for the MTS?
Having fitted a rental 7/8 normal bar I find that I'm sitting in a sporty position, with no bar risers. Other bike is a Dr350SET fitted with fat bar and bar riser/adapter so I'm kinda comfortable with that setup.
Mattel
2012 1200S (Matte Chrome)
wangiles wrote:Hi! I know this is a bit too late to ask but will the rox bar risers affect the DP steering damper? Is a fat bar better than normal bar for the MTS?
No. but that depends. I have a rox and a dp damper, but I took a 1k damper and flipped it upside-down on my 1100s.
The twisted sisters... 07 1100s, 08 1100s & 12PP Angry Duck
ATGATT+AIR!!!
wangiles
Thanks for the reply! How does that look like?
wangiles
Here's the current setup. I'm about to get a rox riser but I'm afraid that it will hinder the damper.
kuyohtay
gorman wrote:I have the exact same setup on my bike (Rox risers and a Renthal CR fatbar). Cables and brake lines are fine - the brake lines are close to the limit but not tight, even with the forks extended to their max (like when you wheelie :-))
I have these, they are the best. They Rox!
Ed.
:mrgreen:
If my ears ain't bleeding, it's not loud enough.
Fly Albatross, fly!
MaverickMotoMedia
has anyone tried moving the handlebars further forward and lower? I have the opposite problem than most, I'm 6'8" and actually prefer a lower more stretched out bar position... there doesn't seem to be much room, though...
