that I was worried about, the thing is to keep the pivot in the same place there is not much play with the mounting bracketsOceanMt_InlandSea wrote:Gregski wrote:I have a question for those who actually used original centre stand when you put bike on the stand is it resting on the front or rear wheel ??
I know it sound doll but I couldn't find any proper picture showing the bike on the stand.
I'm working on redesigning the mounting brackets for the centre stand and wondering what effect on the bike will have moving the pivot for the stand about inch or two forward ?
I am pretty sure that any bike with a center stand is configured so that the front wheel is grounded when up on the center stand.
The main idea for the center stand is to get the rear wheel off the ground for repairs/maintenance. Once the back wheel is off the ground it is pretty easy to put weight on the rear end and raise the front wheel if repairs are needed there, but the reverse is not quite as easy.
No, do not move the mounting point forward.......... the rear wheel needs to be off the ground when on the center stand.
never easy well I try another approach
cheers
