OK, I've TRIED to search like good forum manners dictate, but I need to get answers on these questions. I'd be buying a new 1100S model. For prospective I'm riding a 1200GS now that I'm keeping. I just want something a bit more sporty but w/o the sportbike ergo's.
1) Does the MTS 1100 cruise comfortable at 80-85 MPH? After the 14 tooth c/s sprocket? My older oilheads did, but the current hexhead BMW's with the counterbalancer have a almost multi-cylinder buzz at those speeds
2) Am I correct that the centerstand is an option?
3) DP panniers, how time consuming is it to remove their ugly brackets when not using the panniers?
4) How is the seat-to-peg distance? Has anyone rode a 12GS in comparison? I need to run the seat on my GS in the low position to reach the ground, but then the seat-peg distance is a bit tight on long rides.
Thx from a future Multi owner.
Wanna buy » Search-challenged newbie with some Q's....
Too Many Toys
2008 1100S (Black)
Too Many Toys...
and too little time
2008 1100s 'Ugly Duc'
and too little time
MULTIMENTAL
Tbh if you're keeping the GS, buying a Multi for it's sportiness doesn't sound like such a good idea. You already own a more than capable tourer so I asume that what you're looking for is a bit of fun. I suggest buying the Hypermotard
Shake yourself alive!
Too Many Toys
2008 1100S (Black)
That's were I started, was going to buy a HM. But after riding it & researching things like fuel capacity/range I decided the Hypermotard was a bit too single purpose. Plus I get in enough trouble with my Motard'ed KTM EXC on the street.MULTIMENTAL wrote:Tbh if you're keeping the GS, buying a Multi for it's sportiness doesn't sound like such a good idea. You already own a more than capable tourer so I asume that what you're looking for is a bit of fun. I suggest buying the Hypermotard
The Multi seems to be a Sport Tourer with some soul. I love my GS but I've had a number of them & just want something different to ride now & then. One of my favorite past 'Sunday ride' bikes was a VFR800. I'm thinking that the MTS would be the same in that it would be a blast to jump on & ride 200-300 miles.
(Plus if I keep the GS I'll have something to ride when the Italian steed is down/waiting for parts)
Too Many Toys...
and too little time
and too little time
MULTIMENTAL
The Multi it is then. They are more than capable in the twisties as I proved by keeping up with a 999 though some tight country lanes recently.
I'm 6'1 and can comfortably get both feet flat on the floor with both legs straight. (31" inseam) I find the riding position comfortable for about 3 hours before having to have a long break.
The standard screen is too low on the pre 2005 bikes but there are plenty of aftermarket ones available. I bought a 2005 one of Ebay and it's fine cruising at about 90. (On a private road of course
sally101
1) 80-85 is a good cruising speed. No complaints from the motor.. I have a 14 tooth.Too Many Toys wrote: 1) Does the MTS 1100 cruise comfortable at 80-85 MPH? After the 14 tooth c/s sprocket? My older oilheads did, but the current hexhead BMW's with the counterbalancer have a almost multi-cylinder buzz at those speeds
2) Centerstand is an option. Some owners complaint that it scrapes in a high lean turn.
3) Panniers can be removed pretty easily. It's just a few bolts.. Maybe 10-15 minutes.
4) Go sit on one. Ergos are different for everyone so it's tough try and relate.
Hope that helps.
Sally101 <----- NOT A CHICK!
Just as Sally said.
I think you will love the Multi.
I bumped the rear ride height a 1/2" over stock setting, that eliminates the center stand scraping...and improves handling. For touring, the center stand is a must in my opinion. It makes it so much easier to properly maintain your chain lubrication. When I am traveling, the first thing I do when I get off the bike at the end of the day is to lube the chain while it is still warm.
After you've done it a time of two, you can remove and replace the pannier brackets in just a few minutes. I leave them attached to the paqssenger pegs and take them off also.
