Wanna buy » Buying 03 1000 DS
mot0rhead
2003 1000 DS (Gray)
will pick up tomorrow, anything in particular to look out for?thanks
Do you know what mileage its done ?
Early bikes had soft valve guides ask if they have been done.
if its had a top box check rear frame just around where the rear loop joins back into main frame ....it snaps off.
http://www.multistrada.net/forum/viewto ... pped+frame
is the dash misted and/or missing readout .....its vital to the bike running ....misting means water damage, can be replaced ....Multigatto does them for about £400
slow starting indicates corrosion of earth point...easy fix .....clean and grease.
Keys ...1 red +2 black (needed to activate new dash)
a belt change is easy 1hr job with minimal tools (belts£108)
