jamesmci MTS: Not specified
Booney MTS: 2005 1000S DS (Black)
Joined: 13 Nov 2007 Posts: 1459 Location: France,Midi Pyrenees
Posted: Thu May 31, 2018 5:14 am |
Hi
You have good taste and so we welcome you!
Apart from the usual checks, look at:
Valve guides - Some early bikes had issues. Mine is on the list but runs like a dream!
Rear wheel bearings - Expensive so make sure there's no play wse.
Tank warpage - I'll let someone nearer to you talk about that!
Cambelts and tensioner bearings - check them.
Clutch pack and release bearing - check.
Front discs - Some were prone to warpage - replace with Brembo serie Oro.
Fuel gauge and rear brakes don't work very well but most of us just live with that as
the rest of the bike is AWESOME!
Good Luck
Booney |
_________________ RAW Vegan Plant based Living Foods Nutrition For Optimal HEALTH.
https://www.sens-en-eveil.fr/welcome-english/
05 Ducati Mulistrada Monoposto 1000 S DS Black & Termi'd â¤ï¸ðŸ
70’s Velo Solex 3800s
22 Marin Rift Zone 2 27.5 |
Coleman MTS: 2007 1100S (Black)
Posted: Thu May 31, 2018 11:08 am |
I think you could find one in the same price point with less miles. Sub 15k |
Kerry MTS: 2006 620 (Red)
Joined: 12 Jun 2006 Posts: 128 Location: St. George, Utah
Posted: Sat Jun 02, 2018 8:00 pm |
looks like the "service light" is on, might want to check and see what service is recommended due and how much it will be |
_________________ "Straights are for fast bikes. Turns are for fast riders."
http://bang-fab.blogspot.com/
http://www.dynamicmotorcycleaccessories.com/
06 Red Multistrada 620
00 Aprilia Pegaso 650
01 Red Ducati 748
07 Red Ducati 1098
10 Red Multistrada 1200S |
Posted: Thu Jun 07, 2018 12:54 pm |
Thanks for your input, folks, I really appreciate it.
James |
lotus54 Moderator MTS: 2005 1000S DS (Red)
Joined: 29 Dec 2004 Posts: 4886 Location: Port Angeles, WA USA
Posted: Tue Jun 12, 2018 2:09 pm |
It looks darn good. Generally the valve guide issue showed up by 20k miles. Likely if it runs well and doesn’t use oil it is ok. But it is very easy to check the horizontal exhaust valve guide. Might be worth doing or taking to a local shop for a checkout first.
Fuel tank expansion is another potential issue. From the gaps it may have some. I’d ask the seller and see if it has had the fuel pump gasket recall done.
Is it local to you?
Mark |
_________________ SOLD '05 Multi S resurrected w/custom work
Beta XTrainer 300 |
