Wanna buy » FS: Stock mirrors
MonsieurScaramanger
$40+ shipping. Like new.
1000DS Little Nightmare
http://www.multistrada.net/forum/viewtopic.php?t=18471
ks4hcoach
Hi,
When you get the chance, drop me a line on the mirrors. I sent a PM to you yesterday, but hadn't heard back yet. I wanted to make sure both mirrors had the heads tight on the stem. My left one is a little bit loose vs. the right one. Wouldn't be bad to have a set of spares as well.
Did you put FAR mirrors on yours? Someday I will get a set of these as I really like seeing clearly what is behind me and the stock ones aren't so hot for this.
Let me know as I am very interested.
Rod
Rod
2hlwf8
That's what she said!ks4hcoach wrote:My left one is a little bit loose vs. the right one.
Seriously, i discovered recently that the plastic boot up top can be pulled down to expose a set screw. Take a look and see if it can be tightened. I bet it can but am not certain.
On a long enough timeline, the survival rate for everyone drops to zero.
ks4hcoach
Its the entire head of the mirror itself, where it mounts to the stem, that is a bit loose on my left mirror. The little setscrew you mentioned just helps hold the mirror glass itself at the point where you adjusted it to. I do plan on buying a set of FAR mirrors as most folks say they actually work most of the time. But have been buying other stuff first.
Rod
Rod
